View Single Post
Old 03-20-2011, 07:01 PM
Does you Walbro have a 52 or a 64 stamped inside above the choke plate? How many adjustment screws are on it? The older Walbro 52 had an idle adj screw, a main jet adj screw and a throttle stop adj screw. The later ones did away with the main jet adj. The adj can be found in the tech library section. The procedure is in the Kohler manual. David Kirk at Kirk Engines has played with the Walbro carb a bunch in the past and has some good info on these carbs. Seems around here nobody likes them very much. I say take what ya got and make it better.
