I had some stumps ground down from some trees that were cut last week so I used my 1772 to load up the dirt/chip mixture.
1641
Picked this up:
https://fargo.craigslist.org/grd/d/f...519532633.html Nice gentleman. I told him he should try another ignition switch. Ends up he is only a few miles from my house so I took one over. That fixed it. He still wanted it gone so now I have too many Cubs, just like before I got this one.
1863 48" deck, 3pt 1864 x 2, 54" deck, power bagger, 48” deck 1811 44" deck 1210 44"deck IH trip plow QA42-A, 451 x 2, 551 42" Earthcavator Driveway Drag USAF Shepherd's Chapel |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
I put the 3 point arms on my 984 today. Took a bit to find the right 5/8 clevis pins (2"); luckily Farm & Fleet had 2x 3" multi-hole ones hiding in the wrong bin. Basically a press fit into the bracket on the tractor.
Removed a frozen kingpin/spindle
(AKA Steering Knuckle) from my Cub Cadet 122. Had a buddy come over and spent 45 minutes heating the axle with an oxy- acetylene torch and beating with a 5lb sledge onto a brass drift. Long time since I had such an intense and difficult heat and beat project. |
There is a grease fitting in them for a reason you know!!
I got this CC122 from a fellow that owed me . I used it a couple times but steering was difficult as it was so tight. I was unable to get grease to flow through the existing zerk fittings.
Yesterday, with both king-pins/
spindles (AKA Steering Knuckles) removed, I removed the existing press-in zerk fittings. Then I drilled the hole, tapped the holes for 1/4-28, and then installed new threaded zerk fittings. |
Way to go!!!
