Old 09-26-2016, 11:23 AM
Gstutz Gstutz is offline
I'm curious to Know what tractor those parts came off of.
Old 09-27-2016, 09:56 PM
V30crewcab V30crewcab is offline
it looks like the ps setup off a 1862 to me.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 09-27-2016, 10:06 PM
Or 1864.....
Old 09-27-2016, 10:14 PM
FWIW,
I set my ps pump above the crossmember.
I made a "C" bracket and bolted it to the bottom of the pump and bolted the bottom of fabbed bracket to the top of the cross member.
I used column/pump from a 318 Deere.
seems like the "C" bracket was less than 3" high.
Old 09-27-2016, 10:16 PM
Just as a note, this thread is 3 years old.....
Old 09-27-2016, 10:20 PM
Opps, past my bedtime.
Old 09-28-2016, 12:07 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
The new bracket you have is for a super and mounts to the side of the frame you need a bracket from a 1864that goes to the crossmember.I used one for a pattern and had to make one longer to drop my column from a super.The bracket I used mounts to the side of the frame
Old 09-28-2016, 12:10 PM
I wouldn't waste my time or money putting power steering on a cub, I put a set of Firestone tri ribs on my 1211 and I can steer it with my pinky finger. I also had deestone tri ribs on my 122 and it steered just as easy.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-28-2016, 11:20 PM
Yeah, but you're a big muscular kinda guy...
I do have them (Firestone tri ribs) on the 1650, and it steers so much easier than any other front tires. BUT after using the 1872 with power steering, there is a big difference for us less "big muscular kinda guys"...
Old 09-30-2016, 07:51 PM
Maple Cabin's Avatar
Maple Cabin Maple Cabin is offline
The bracket assembly that I made up works fine. My first design was close (needed to grind a bit to make room). The new bracket assembly has the modes for clearance. So this will let anyone to put power steering on any tractor that used the same mount as standard steering. (crossmember)
Power steering on a mounted snowblower is night and day and think about a loader tractor. Even cutting grass.
From 129 to 782 plus can have power steering with a hydro setup.
Doug
126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights
129 Deck, Blade, Weights
1200 Creeper Deck: 1250 B Tiller odd deck
782R with power steering
JD 110H:JD 112H
