Old 10-19-2009, 09:31 PM
Mountain Heritage's Avatar
gee whiz Matt, you plowing in a rock pit? Holy crap, I know we have some stoney land around here, but you only have a Cub you know......plan on burring some boulders with it?
Old 10-19-2009, 10:19 PM
aagitch,
This is the 1st one i built, Cant really tell in the picture but its bent a little like yours is.
The next one i built i tied the part that the lift links hook to all the way to the cross brace. I havent tried it yet but it seems like this would brace it pretty good.
Old 11-10-2009, 11:55 AM
Just wondering....would it be wise to put brass bushings on the "u" bracket where it attaches to the tractor?? Or would that be a waste of time (too soft, not really needed etc...?)
Old 11-14-2009, 01:59 PM
aagitch's Avatar
aagitch aagitch is offline
If i attach a tiller gear box to the rear of my 782, can i still attach a brinly adapter to the rear without pulling the gearbox? or does the brinly adapter attach where the tiller would mount to the gbox?
Old 11-14-2009, 09:39 PM
Merk Merk is offline
by Mountain Heritage
Brass bushing(s) are too soft.
by aagitch
You will have to add 2 1/2 to 3 inches to the sleeve hitch arms and upper link.
Old 11-16-2009, 11:04 AM
eastonct124's Avatar
eastonct124 eastonct124 is offline
After you straighten it out, wht don't you Harden, then Temper it?
Simple prodcedure, you'll just need a wide pan and alot of oil to do the Hardening.
Fly Fishing is not a sport...It's a way of life.
Old 05-23-2013, 08:41 PM
swampyankee1973 swampyankee1973 is offline
Default Last weekends project
The hitch pins were just for a quick functionality test. I will use bolts foractual work. I fabricated the eentire hitch out of scrap around the garage. The majority of construction is from angle iron. The liftbar is 3/4"x2" bar stock which is welded to the pin tube as well as to the front and rear angle iron looking forward to seeing how it holds up.
Old 05-23-2013, 08:44 PM
Sorry I don't know why the pic posted sideways
Old 05-23-2013, 08:51 PM
That pic would be correct if you were plowing my neighbors garden!! A little steep!!
Old 05-23-2013, 09:05 PM
Looks OK to me..
