Greg Rozar AKA- CubDieselFan
Old 01-29-2017, 10:44 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Originally Posted by farmall fred View Post
Thanks.
I first seen this tool at a friends shop where he builds Hot Rods and could not believe how easy it was to use. When I asked where he bought his I was shocked at the price. His is not a Eastwood but is the same tool. He paid way more than the price at Eastwood. If you buy one you will not regret it. I tried many other flaring tools over the years and none come close to this one.
Good find
I'm tools addicted! Buying the right stuff is the name of the game to avoid the word regret.
Keep the amazing work and post ton's of picture please!
Gilles.
1963 100 (red)/in storage
Old 02-02-2017, 10:18 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Default Progress update
Spent the last few days removing paint and powder coat. The paint on the older sheet metal was easy to remove, the powder coat on the Cyclops parts not so easy. when sanding it it is like trying to sand rubber. Using Black Beauty in the blast cabinet will take it off but it is a real slow process. I have all of the sheet metal stripped except the rear fender pan. Hope to get that done tomorrow. Since I am running the rear fuel tank from the Cyclops I needed to fill the hole in the hood. I cut off the rolled edge around the opening and butt welded in a patch. I was surprised that I had very little warpage to deal with. A little time with a hammer and dolly and it came out very good. Once I have the fender pan stripped I will clean well with wax and grease remover and apply two coats of Epoxy primer followed with a little body fill where needed than three coats of high build urethane 2K primer followed by block sanding. If all is good I will apply a sealer coat of reduced epoxy then IH 2150 with hardener. On this job I am going to try clear coating with Polyurethane clear. I have never tried it but know others who have done it. I will let the 2150 cure for a week and than skuff sand it with 1000 grit and spray some clear. Before trying this of the good parts I will do a test panel to be sure the color and clear are compatible. Here are some progress pics. Wont be long before I can squirt some paint. I recently bought a new Iwata LPH400 Spray Gun to spray my 57 Chevy so this will be a good place to try it out.
Later
Tom
Top side of hood.
Bottom side of hood. The dark spots are some minor pits and low spots in the welds. A very light skim of filler will take care of them.
Over all view of hood.
Sanded parts ready for Epoxy
These three parts required about fours in the blast cabinet.
Battery box done just needs hold down.
Old 02-02-2017, 10:51 PM
Terry C's Avatar
Terry C Terry C is offline
Nice work! Looking good.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 02-02-2017, 11:59 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Great metal work!! Looks like you are moving on!!
Jay
Proud owner of the following:
Old 02-03-2017, 04:59 AM
Dirty Steve's Avatar
I like your build. Excellent work!
Old 02-03-2017, 05:50 AM
cubby102's Avatar
cubby102 cubby102 is offline
I'm jealous...
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 02-03-2017, 08:40 AM
Thanks guys. I enjoy doing this kind of work. One of my hobbys is restoring old Chevys and antique Farmall tractors. My biggest problem is the eyes are not what they used to be, I tried to tig weld the patch in the hood but just could not see well enough to weld the thin metal so I had to resort to the Mig. It got the job done but it took more grinding to get it finished.
Tom
Old 02-03-2017, 10:21 PM
jcsmith jcsmith is offline
Can't wait to see the finished tractor. You are a true craftsman . Would like to see some photos of your '57 chebby.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 02-04-2017, 12:28 AM
johncub7172's Avatar
Thumbs up
Nice going on this Super! Keep up the good work!
Old 02-04-2017, 11:50 AM
Chris
I started a thread in the general talk section about my 57 Chevy project for any one interested. Hope you enjoy it.
Tom
Link
http://www.onlycubcadets.net/forum/s...537#post408537
