Greg Rozar AKA- CubDieselFan
Old 11-26-2023, 09:41 AM
Hopkids Hopkids is offline
Question Engine kills when disengage brake,
I have a zero turn mower, CC 17AF3AGV010, Z-force 48. The mower starts but when I disengage the brake, it kills. I have replaced 4 brake switches, and each time it fixes the problem. I mow, then let the mower sit for a week or so, then this happens again. I have tested the seat switch for continuity (male) and it is good. I have cleaned out the connector (female) with electric cleaner, and cannot find any wire breaks. The little micro switch in the seat connector (female) seems to be moving freely. I am perplexed, does anyone have any help? Thanks. (I am new to this forum, first post. If I need to post this on a different page, let me know)
Old 11-27-2023, 06:51 AM
Here is the wiring diagram if you don't already have it.
https://www.ccpartsnmore.com/cub-cad...ing-schematics
Looks like the seat and brake switch are the only 2 things that will kill the engine. If it runs fine until you release the brake then it sounds like the seat switch is your issue. Time to break out the meter and do a little testing. Let us know what you find out.
Old 11-28-2023, 05:40 AM
thank you. The seat switch has continuity when pressed, so I think that means it is good? Could it be that the connector to the brake switch on the harness is bad? Am I able to get just that connector?
Old 11-28-2023, 09:52 PM
Can you post a picture of it?
Old 11-29-2023, 06:34 AM
Thank you for responding. I discovered the issue to be in the seat switch. When I checked it, there was continuity, so I assumed it was working properly. I installed a new brake switch, mower worked. Sat overnight, did not work in the morning. I put in a new seat switch, worked. 10 minutes later, did not work. The problem is the little micro-switch in the seat switch connector, it does not get pushed down far enough sometimes, even with a new switch. as long as I reconnect the seat switch, it works. I am wondering if I can get that seat switch connector (on the harness) without having to purchase the entire harness.
Old 11-30-2023, 05:15 AM
If I understand your issue, can you just cut the plug out and use butt connectors or spade connectors if its on the switch?
Old 11-30-2023, 05:38 AM
Thanks. No, I can't. The plug has a microswitch built in, so I can't just 'hot wire' it. I will need the plug. So far, I have not been able to find it alone, without buying the entire harness
Old 11-30-2023, 12:03 PM
If you are a light weight you may want to add weight to the seat, bouncing around may trigger the seat switch to act that way you describe...
Up to 530 and counting...
Old 03-04-2024, 08:36 PM
CubDieselFan's Avatar
This info is from the model number you provided. The seat switch is still available form Cub Cadet.
Old 04-10-2024, 08:56 PM
HIOKR2 HIOKR2 is offline
I resolved this problem by separating the harness connector between the rear of the tractor and entering the engine. On my 2018 TR2 LX46 EFI this is located near the oil dipstick & oil filter. I blew the debris from the connector, sprayed DeOxit contact cleaner to the terminals and reassembled the connector. Problem fixed.
