Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 04-05-2018, 08:44 AM
taylorjm taylorjm is offline
Default 2182 oil plug
This went from a minor annoyance to a full fledged pain the in the butt. My 2182 with the gas Kubota has always had a little drip from the oil plug, figured next oil change I'd fix it. Pulled the plug, put on a new crush washer, still drips. Not a lot, maybe a drip every couple days, but enough to tick me off. I'm all into making sure things are tight, but any tighter than it already is, and I'm going to worry. Any tips, tricks, advice? Maybe a different kind of washer someone uses with success? I looked for any nicks or gouges in the mating surfaces and didn't see anything.
Old 04-05-2018, 08:53 AM
Originally Posted by taylorjm View Post
Ok, this went from a minor annoyance to a full fledged pain the in the butt. My 2182 with the gas kubota has always had a little drip from the oil plug, figured next oil change I'd fix it. Pulled the plug, put on a new crush washer, still drips. Not a lot, maybe a drip every couple days, but enough to tick me off. I'm all into making sure things are tight, but any tighter than it already is, and I'm going to worry. Any tips, tricks, advice? Maybe a different kind of washer someone uses with success? I looked for any nicks or gouges in the mating surfaces and didn't see anything.
----In situations like that I cut an "O" ring groove in the bolt head.
----Or make a nylon or teflon washer.
----or use a copper spark plug washer.
If that fails weld it shut Ha,LOL!
Old 04-05-2018, 09:04 AM
Along with what George said.....
Use teflon on the threads.
Drain port on the oil pan may have a crack.
Drain plug may just be worn out.
Old 04-05-2018, 09:22 AM
Thanks, I did teflon wrap the heck out of the plug, but since it's not a tapered thread, but relies on the washer to seal, that didn't work out as well as I thought. I guess I could take the plug to napa and see if they can match it and get me some washers to try. If that fails, I'll just spray flex seal all over the oil pan. If it's good enough to hold a boat together, then it should be able to fix an oil leak! lol
Old 04-05-2018, 09:23 AM
Ok George, I gotta ask. How do you cut an o-ring grove in a bolt head that small, and round to seat an o-ring in? Dremel?
Old 04-05-2018, 09:31 AM
Lathe......
Old 04-05-2018, 10:19 AM
Lathe......
That jon "kid"is pretty smart for a young whipper snapper.
As he said inspect the surface where the sealing washer seats.
I have seen aluminum and steel oil pans crack.
(not familiar with a 'bota)
usually a soft nylon washer will conform to slight irregular surfaces.
FWIW some vehicle drain bolts do have an "O" ring headed bolt.
you might look/compare in the "help" section of better auto parts stores.
I would recommend asking the counter person, but most have no clue unless you specify year make & model.
being a 'bota it is going to have a metric thread.
Try a google search for the problem, someone might of already solved the problem.
Old 04-05-2018, 11:01 AM
Thank you. Went and got a new plug and a ribbed nylon washer. I'll give that a try and see if it takes care of it! The new plug has a larger head, and the washer is larger, so hopefully it has more room to seal. The previous plug and copper washer was more like the size you get on a spark plug. Pretty narrow. I think this will seal it much better.
Old 04-05-2018, 12:03 PM
With a ribbed washer and a bigger head, the results should be more satisfying.
Old 04-05-2018, 12:26 PM
Terry C's Avatar
Terry C Terry C is offline
That tickled my funny bone!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
