Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 06-01-2021, 05:29 AM
hugo454's Avatar
hugo454 hugo454 is offline
Default Fuel solenoid install help
The fuel cut-off solenoid on the 1782, I have is not mechanically connected to anything. I need to wire it up, but once I do, I still will have the plunger side not physically operating anything. Does anyone have a pic of the solenoid and what it engages?
Thanks
Old 06-01-2021, 06:27 AM
Leadslingingdaddy's Avatar
Is that a Magnum in that 1872?
Old 06-01-2021, 06:37 AM
hugo454's Avatar
Magnum?
has a 640 diesel in it
Old 06-01-2021, 06:51 AM
hugo454's Avatar
current situation.
Old 06-01-2021, 01:07 PM
Dooh i read that number wrong!
Old 06-23-2021, 07:13 AM
hugo454's Avatar
I'm going with a manual "pull to turn off" cable to the injector pump stop lever instead. Also have decided to go with a compact 1 wire alternator. Also Bosch 1 1/2" gauges to monitor engine temp, oil, volts and a glow plug circuit controlled by the key switch with a Ford type starter solenoid relay.The entire factory harness will be removed.
