Greg Rozar AKA- CubDieselFan
Old 01-29-2018, 06:35 PM
RLause's Avatar
RLause RLause is offline
Default 782 Dual Hydraulics
Anyone thinking about going to dual hydraulics might want to take a look at this valve on epay.
https://www.ebay.com/itm/JOHN-DEERE-...72.m2749.l2649
I just installed one on mine and it works well. The lines fit just like the originals. I had to weld a small tab onto the mounting plate because of the extra width of the valve and filed the handle slot longer for the detent position. Also the price was right.
Richard
Old 01-29-2018, 09:31 PM
Yep! JD valves fit and are MUCH cheaper than IH ones. FWIW, you can also install a 3 spool JD valve and separate the center and rear lifts, or have a center lift and two auxiliary remotes.
Old 01-29-2018, 10:49 PM
RLause's Avatar
I forgot to mention that if you intend to use the detent function, make sure you check it out before you install the valve. Mine was all rusty and yucky. I also unscrewed the detent stem and installed a washer .008" thick to reposition the notches created by wear, 1/2 way between the detent balls.
Richard
Old 02-02-2018, 07:00 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Or...
1- 1200 in pieces
1- 1864 in pieces
Old 02-02-2018, 07:27 PM
samckitt samckitt is offline
Is there such a thing as a 4 spool valve that will fit, center, rear & 2 separate port control.....? Or use 2 2 spool valves....?
________________________
Scot
Old 02-02-2018, 08:28 PM
Not like the original ones. But you can get stackable valves, or do like Rescue 11 and use splitter valves.
