Greg Rozar AKA- CubDieselFan
Old 01-01-2018, 01:19 PM
Originally Posted by charlie105 View Post
Jeff; It is a single spring. ? Cast in pins ?
Thanks ,Steve
On the hub, one style is smooth and the other has 6 pins .
I just machined both the hub and the plate on this 6 pin style hub.
Old 01-01-2018, 05:50 PM
charlie105's Avatar
charlie105 charlie105 is offline
OK, our’s Is Smooth.
Old 01-02-2018, 08:06 AM
charlie105's Avatar
Jeff; Why do you ask ?
Old 01-02-2018, 06:26 PM
charlie105's Avatar
While I was picking up the PTO pressure spring at our local Cub Cadet dealer, I learned that many of the kit supplied gauges were wrong. Apparently the owner, a second generation Cub dealer, had a procedure they came up with in the 70’s. for installing the spring effectively. —-He was out today. I’ll find out what their procedure is tomorrow. I’m curious, because when I rebuilt it 4-5 years ago I thought the spring was depressed too much when adjusted with the gauge supplied in the repair kit, and the spring was bent when I removed it this weekend.
Old 01-02-2018, 08:05 PM
You use the double spring with the "6 pin" hub.
I have double spring PTO's on both my 125's
Old 10-15-2018, 06:28 PM
Albertj Albertj is offline
Default Springy Springs
Probably a typo for "rebend"
Would have to heat treat it I think, then temper it. Hereis a link with details -- https://www.smokstak.com/forum/showthread.php?t=42776 -- first get the part red hot (orange-red, around 850F), re-flatten, and water quench it. That is the hardening part of the heat treatment and will make it brittle, but **Then** you clean off the scale and temper it by heating at around 450 degrees F. at which it will take on a uniform blue color once it hits about that temp - then let it cool to room temp, which wont take all that long 'cause it's small. You might want to practice on some scrap. Parts this small, you are likely using a torch for the heating.
A Google will find you much more detailed information on forming and heat treating spring steel.
It will be tricky to figure out how to hold the little bugger so you can get it uniformly hot. Coat-hanger wire loop thru the middle comes to mind. (it will get red and embrittle, too - sacrificial...)
