Greg Rozar AKA- CubDieselFan
Old 07-18-2018, 10:45 PM
John, the brackets on front should be just wide enough to clear the frame. If they aren't, they are bent. You didn't weld a new pin on. It has to have two pins, or you will have to bolt it on. Either way is fine. That frame is meant for both narrow frames with the QA mount up front, and the old bolt on style, like the O-the 1X2/3 series. The pins should line up and snap into the QA latch. When it is latched in, the holes in the top of the blade bracket should also line up with the corresponding holes in the frame.
You got the rear mount in the right spot. Goes on the outside of the frame.
The yellow bracket in the last pic behind the foot rest/ lift bar is a PO mod. Remove it.
Old 07-19-2018, 12:12 PM
john hall's Avatar
Thanks!. Yeah, wanted to "fit" everything before I put in the new pin. The arms to the back look straight, just having to bow them open about a 1/2" each, not a problem, just wanted to make sure I wasn't missing the obvious. The PO added brackets are way to the back out of the way of everything, a lot of work to remove them unless a proper restoration were to happen---you know me, that ain't happening--gonna get it working and reliable and use it (barely). I am looking forward to keeping it near the house to clear in front of the garage for the couple snows we get every year--no fun pulling in and out of the garage on ice.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
