Greg Rozar AKA- CubDieselFan
Old 10-08-2023, 01:23 PM
Higgy Higgy is offline
Default Cub Cadet 1330 Hydrostatic Transmission problemss
I'm at my wits end and need some help with the following questions?
(1) What would make the brake rotor on a Cub Cadet 1330 lawn tractor stop spinning? That situation has resulted in no brakes for the lawn tractor when otherwise the hydrostatic transmission works well, and the tractor moves in both directions with a strong forward and reverse.
(2) Also, the hydrostatic dump valve on the back of the hydrostatic pump no longer allows the drive wheels to free wheel so the tractor can be moved in neutral. What would likely be the cause of that? I swapped a dump valve from another Cub Cadet 1330 with a working hydrostatic transaxle with no effect. I didn't check when installing the new pump, but could it be a broken hydro coupler perhaps?
Both of these problems arose after replacing a failed hydrostatic pump with a used one I purchased. These problems leave me with a mower having no brakes which is dangerous if a drive belt breaks while mowing on a hill.
Old 10-09-2023, 07:29 AM
ironman's Avatar
ironman ironman is offline
Simple answers:
No brakes, brake disc not spinning ----- woodruff key sheared (part no. 46)
Hydro not releasing ----- lever or spirol pin broken or missing (part nos. 17 & 18)
Old 10-12-2023, 12:25 PM
As a follow-up, I discovered that all the couplers in the transaxle were in good shape but the replacement Hydro pump I purchased and installed on my Cub Cadet 1330 lawn tractor wasn't.
The Hydros on these model lawn tractors are the weakest part of the machine. Although disappointing it was not surprising given the age of my tractor. The Cub Cadet 1330's and parts from them are more than 30 years old having only been produced until 1992. Purchased new mine has proven to a work horse requiring only normal maintenance and providing many years of dependable service.
But with time on my hands and being stubborn I once again removed the transaxle from the tractor and removed the hydro from it (quite a time-consuming chore for an old guy) in an attempt to diagnose the problem. I immediately noticed leakage of hydrostatic fluid around the hydro pump located underneath the hydro couplers driving the brake rotor. Digging a little deeper, when spinning the couplers from the input shaft driveline to the pump) it was evident that the wheels moved but the couplers driving the brake rotor weren't working properly and only turned sporadically.
Wanting to salvage this tractor for sentimental reasons (which is otherwise in excellent shape) I've exemplified the definition of insanity and purchased yet another Hydro pump which is scheduled for delivery next week. But this time it was an expensive brand-new BDU-10S-215 hydro pump (ouch).
After I've installed it, and reassembled the transaxle to the lawn tractor, I'll let you know how it turns out.
Old 10-14-2023, 02:16 PM
Thanks for the update it helps others and we always like follow ups.
Looking fwd to your continued updates.
Best of luck--- us old farts rule, Ha,LOL
Tractor data sez '92-'93 years produced.
