Greg Rozar AKA- CubDieselFan
Old 11-22-2023, 11:20 AM
cubbyjunior cubbyjunior is offline
Default I want to replace/improve the "twist and pull" oil drain
I have a 2020 XT2 LX46 lawn tractor, and I hate the twist and pull oil drain. First, it loosened up and leaked some oil and made a mess in my shed. Second, I can never drain the oil without it leaking down over the frame, whether I use the plastic tube or not.
What I would like to do is install a short pipe that extends out past the frame so I can drain the oil into a drain pan without making a mess. I'm sure I'm not the only one who has this problem. Has anyone fashioned an easy fix?
Old 11-22-2023, 02:24 PM
ironman's Avatar
ironman ironman is offline
yes easy peezy
Old 11-22-2023, 06:02 PM
Ozcubowner's Avatar
Ozcubowner Ozcubowner is offline
Like Ironman says eezy peezy , but I went a slightly different route
Unscrew your oil fitting take it to a store that sells hydraulic fittings etc and get 1 fitting , one end same size as screw end of oil fitting other end with a hose fitting , then get the female equivalent of that fitting and a screw in plug
All you now need is a length of hose and 2 hose clamps
Sounds complicated but it is dead set easy and you can have the hose as long as you like
No more oil on the Cub
I have seen a number of machines that use what I have that where I got the idea
Oz
Old 11-22-2023, 07:26 PM
Spilled oil is good, it keeps the rust at bay!
Old 11-23-2023, 02:18 PM
Thanks. I was originally thinking of the first idea, but either would work for sure.
I guess I need to wait until the next oil change to screw out the current fitting to make sure about the thread size. Or collect the clean oil I just put in and refill with it.
