Yes, I pulled the pully to move it closer to the spring too and tried the other tips you gave me here too. I did have the spring end pointing down since this how it is supposed to be attached. I need to be able to hold the spring somewhat vertical to insert the spring, but other parts are in the way such as the belt and the brake rod. The spring must go under these parts. I've never had this much pain trying to attach a spring before, and I think I may have to detach some of the deck itself so I can move it back to the rear a bit. Replacing a PTO cable should be easier than this and it should be engineered better to perform this.
Cub Cadet XT1 LT42 (2015) Model: 13AVA1CS056 (SV541-3212) 4-Stroke, Single. Kohler Courage 18HP 597cc |
If you were normally removing or re-mounting the deck, hooking the spring into the hole in the arm is the first (if installing), or last (if removing) thing you do. It is not difficult because you have the deck slid about half way in or out and everything is more or less out in the open. Your manual should explain the procedure.
