CC Speciaalties R. F. Houtz and Sons
Patton Acres IH Cub Cadet Parts
Greg Rozar AKA- CubDieselFan
Old 03-10-2011, 04:40 PM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
Default 128 Jumps out of Reverse
Our one 128 keeps jumping out of reverse. It does not do it in any other gear. What might be the cause? I removed the fender deck, and need to clean the top of the transmission and shifter cover before iI remove it. Any help will be very greatful!! I figured that I woul dtry to fix this while the engine is out for a clean up, base gasket and PTO clutch adjustments.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 03-10-2011, 05:19 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
A good guess would be a bent/damaged shift fork(s).
Nemesis
Old 03-10-2011, 05:29 PM
cub123's Avatar
cub123 cub123 is offline
I would say its your shifter fork is broken,plus the gear for reverse is worn,causing it to pop out. Check this out.....
part 1
http://www.onlycubcadets.net/forum/s...ead.php?t=4624
part 2
http://www.onlycubcadets.net/forum/s...ead.php?t=4625
part 3
http://www.onlycubcadets.net/forum/s...ead.php?t=4626
This does not deal with the forks,but might be useful. The forks tend to crack and then twist,thus not putting it fully into gear,which then starts popping out and rounds the gear over and it wont stay in at all.If the fork is cracked it will need to be replaced or welded,(i like to add some metel around it when fixing it to make it a little stronger)and the reverse gears replaced.If you have to tear into it a manual will be helpful(i did mine without it just fine),but if you do it without it be SURE you keep everything in order.
Old 03-10-2011, 07:27 PM
Mike in NC's Avatar
Thanks for the info. I took the cover off and the shift fork bolt was way loose. I tightened it up. I looked at the fork and it doesn't appear to be cracked or broken. After it is back together I hope that fixed it.
Old 03-10-2011, 09:24 PM
cub123's Avatar
Sure hope that fixes it for you! Glad that it didnt have anything broken.
Old 03-10-2011, 09:33 PM
eastonct124's Avatar
eastonct124 eastonct124 is offline
Both my 122, and 124 had that problem. And, the fork was broken on both.
I tightened them up, because I didn't have time to split the chassis on either.
You just need to <gently> finger the shifter into gear...don't force it, and it will work temporarily.
Fly Fishing is not a sport...It's a way of life.
Old 03-10-2011, 07:55 PM
chris chris is offline
Talking jumps out of gear
it is probably a broken shifter fork from what i have experienced,
Chris Westfall - Cub Cadet Classics
