Identifying Kohler KT17 Series I & II
I have a 782 s/n 2050594U683758. The spec. # and model on the Kohler have worn off. The housing on the engine says Series II. Is it correct for the tractor and how can you tell the differance between the two engines?Is there anywhere else on the engine that has numbers stamped?
Hi Curtis,
the Engine in my Cub is a Kohler KT 17 Series 2 too. The Nubers at my Engine are: Spec. Nr.: 24302, Model Nr.: KT17S, mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!! |
that engine is most likely a replacement engine. According to your 782's serial number, it is too old to have had a Series II in it from the factory.
According to the Parts Manuals, and if everything is original, here is the breakdown:
Series I were installed in Chassis Serial Numbers below 726124 Series II were installed in Chassis Serial Numbers above 726125
The housing says Series II or the air cleaner? May just be a replacement air cleaner cover. Can you see a provision for an external oil filter on the right side? (I think that's right) Some Series II's have this as an option. Not all, but some if I remember right. Go to Kohlers website and download the manual for the KT17 it will have more info as to help tell the difference.
Disclaimer... I may be way off here as I've never had one, just regurgitating what I've read previously on other forums.
I like pie |
If you look at my picture and follow where the two lines hook to the engine, that's where you would have an oil filter adapter block-off plate installed with two allenhead bolts. If it has this, it's definitely a series II. But like Keith said, some of the early series II didn't have this.
here's a better picture for you
My 782 is an '84 or '85 and its series II doesn't have the oil filter provision, either.
Kohler KT Seriws I & II Questions
It says series II on the engine cover and has a spin off oil filter. Does that tell you guys anything?
It's definitely a Series II then. Spec should be 24302. That's definitely not the original engine for that tractor which is a good thing. It most likely came from the factory with a Series I. Is your serial number worn off on the engine also. You can tell what year it was made by the serial number. My Series II was built in '94.
