Setting up the moldboard plow
A long time ago I saw pics of someone setting up a moldboard plow using concrete blocks and 2 x 4's under the tractor. I've been trying to find it again for a couple years with no luck. I thought it was on this site but using the search box produces 0 matches. Does anyone else recall this? My plow worked best that year and would like to get it set up that way again. Thanks, Roy
I have seen the light!.....oh wait, thats the headlights on my 126! 107, 126 Pincor generator Haban 402d sickle bar Brinly rear scraper snowblower rear tiller |
All you do is put blocks under the rear wheels same height as the depth you run and set the plow level on the floor.
FWIW, it's not hard to adjust in the field. |
Ok, the plow sitting flat on the floor was one part I couldn't remember, also, I couldn't remember which holes to put the lift frame in. Thank you gentlemen, greatly appreciated! I had also been reading the intruction on the Brinly Hardy website and didn't realize the plow i supposed to float side to side! Oops! Roy
Which holes are you talking about? The ones on the lower bracket on the tractor? Or the 3 on the plow frame? There is no certain place to put a plow on either one of those. They will be different depending on the tractor they are on, and possibly soil type.
OCC is so cool, I had no idea a plow needs to be set up for a certain tractor. That explains why mine didn't work as well as I thought it should.
One lonely old 1541, 3pt, Brinly plow and cultivator. |
Left front tire should be blocked up the same height as the rear tire.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
I really should get the 147R set up and plow something A friend has been bugging me to do this. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
