-   -   New addition (https://www.onlycubcadets.net/forum/showthread.php?t=46990)
sorner 01-31-2017 09:05 PM
Originally Posted by Shrewcub (Post 408206)
sorner, I just looked at the 1864 in great falls, looks like he upped it to $1250!:bigeyes:
Dirty pool mister, dirty pool. :biggrin2:
Sam Mac 02-01-2017 05:15 PM
Got the JD's transplant finished today. Successful mission. Cleaned and reassembled the drive shaft and steering shaft. The CH22 is mounted to the motor plate and just about ready to drop into the Cub. So far everything is going as planned. If it's warm tomorrow I hope to get the Cub washed. It still has some crud on the frame under where the motor plate sits that I couldn't get at before.:beerchug:
sorner 02-01-2017 06:19 PM
Is that crud from the driveshaft boot leaking? Mine had that crud too when I took the engine out. And inside the shroud of the engine there was thick greasy crud that I had to clean up. The seals seem fine, I don't think it was engine oil.
Sam Mac 02-01-2017 07:59 PM
This one had a leaking seal on the flywheel end and it oiled the whole tractor. Only good thing is all the bolts come out easy after you find them. :biggrin2:
Sam Mac 02-02-2017 05:20 PM
Pig Pen is all nice and clean. Engine is about ready to drop into the frame. Gotta do a little paint work on the heat shield first. New PTO is on. I'll try and get off my lazy butt and get some pics tomorrow. :beerchug:
Sam Mac 02-05-2017 05:00 PM
5 Attachment(s)
Steering column is back in, cut a hole in the dash for a voltmeter and stuck it in the hole. Installed the starter relay that was on the tractor when I bought it. Next on the list is to make a wiring harness then drop the engine in. Here are some pics. :beerchug:
CubDieselFan 02-05-2017 05:14 PM
Looking good Sam, should be a grass killing machine.
john hall 02-05-2017 05:50 PM
Looking good. How come the voltmeter? Is it a "cool factor" or was the electrical system problematic? You'd think with all those warning lights in the dash there would be an idiot light.:bigthink:
Dirty Steve 02-05-2017 06:18 PM
:beerchug: Looking good Sam. :beerchug:
Sam Mac 02-06-2017 08:39 AM
John
The Cyclops tractors have a voltage light that rarely works. With a voltmeter you know for sure what is going on. To your question about the condition of the electric system on this tractor, just about every connector was melted from corrosion causing poor contact. I'm redoing the complete system.
