| cub149 |
07-23-2013 10:09 PM |
I finally got the pump mounted and wired in this weekend. I have to say this thing runs smoother, quieter and much cooler than ever. The throttle response is much better and it idles so smooth. It ran great before but it is a noticeable difference. Could the manual pump have been going bad for a while and just not putting enough pressure to the carb and causing it to run lean?
Either way, thanks for the help. Electric is the way to go. Much cheaper than a manual pump, and if it goes bad REALLY easy to change out.
