Why don't you try soaking/overhauling the carb. and setting it up properly ?? A lean condition will make them run hot. If it has the adjustable carb on it , it would be no big deal.
You could also check the timing. Does it have the right spark plugs in it ?? Does the tractor have the foam pads attached to the tank bracket and under the blower housing ?? Those are needed to help seal the blower housing to direct air over the engine. And yes , there is supposed to be a foam pad glued to the motor mount that the blower housing sits on. They are still available to buy or you could make something to do the same thing. It is your tractor , but if the engine doesn't rattle or smoke , why not take some time and diagnose what the problem is ?? It may be just a good carb cleaning or the timing is off. Good luck !! |
You may want to consider something like this
http://www.summitracing.com/parts/sid-mt-pro Then you will know if it is truly running hot and if it is where it's hot. |
Why does everyone think their air cooled engine runs hot? Of course it does. It's a motor, cooled with air. YES, it gets too hot to touch after running for ten minuets..... DUH! Grab a temp gun like Sam suggested and check it out. |
1. Fix the Carb 2. Replace the Carb 3. Tell us that you concluded your experiment on how long it takes to blow up a lean running engine. |
What are normal temp readings for the cylinder jugs while running? What would be concidered too hot?
Chris |
Allen , I knew there was supposed to be the foam around the tank stand , but i didn't realize there was supposed to be a strip on the bottom of the blower housing between the blower housing/engine plate until i brought home a 682 and 782 and both of them had it.
I just got both strips from partstree and put them on my 1872 and what a difference on airflow out the front of the tractor. They come peel/stick. I needed to do some engine repairs on my tractor and i had to pull the engine and i replaced them. You don't have to pull the engine to put the foam on the tank stand , but obviously you do for the bottom. It goes from one side of the frame to the other. I guess you could find something to place under the blower housing if you take the tank stand out. I have a 482 that has a round piece of sheetmetal screwed to the tabs on the tank stand instead of the foam. Best i can show you is from partstree , the foam is 14/15 |
| All times are GMT -4. The time now is 04:42 AM. |
