Glad to hear you made it home safe Ryan!
What's your plans for it?:bigthink: |
I dont know...lets hear some suggestions! What should I do with this little guy?
Well lets see, leave it in your truck. take it to work and drain the oil. put it on a pallet and wire it down. Then I send speedie to come pick it up.
Ps put the rims on the pallet too |
4 Attachment(s)
Just came in from a joy ride with it. It had some noticeable issues since I first heard it run this morning. First, the condenser was bad. It would run very rough at high idle and die. So, pulled one out of the parts shelf and fixed that. The negative side coil nut was loose too. And the battery kept losing charge, so I noticed that one VR wire was broke. I spliced it up and it was good to go, back to charging. Still need to change oil, grease the very tight front end, and find a new air cleaner...
Here are some close up pics! |
We shall see! :biggrin2: It also needs the lift handle fixed and all the PTO linkage reinstalled. |
It also has the dreaded PO cut out above the transmission! See above pics.
I like 73s. They look like their bigger brothers on the front till you get to the steering wheel then it's like 10 years back as a 70.
I agree with the above statement! A combo of old and new looks...I always wanted one simply because I liked the white metal dash. |
The 73 was built in May of 1970.
| All times are GMT -4. The time now is 09:44 PM. |
