-   -   The KY 782 ??? is MTD (https://www.onlycubcadets.net/forum/showthread.php?t=39000)
R Bedell 05-23-2015 06:59 AM
Something wrong with that picture....:bigthink:
(A) Someone has put the wrong hood decal on it.
or
(B) Someone has painted a Yellow & White (MTD version) red.
Oak 05-23-2015 09:25 AM
I'm thinking the hood was repainted. The -399 shows it was a red 782 but that decal is from a white hood off of a -100 tractor.
snoel 05-23-2015 11:50 AM
After de-grease, and pressure washed.
Hood was replaced with 682 hood.
And, who puts that seat, on a cub? I did. Not recommended for cubs with seat/fender pan and rear mounted battery. just too high. Might work ok on a NF without full fender pan and rear battery. But I had to try it. It will eventually get replaced with correct seat.
It has the CC 3pt lift. Need the sleeve hitch. not much more going to be done to it, until I get the 169 back together.
snoel 05-23-2015 11:56 AM
I did get the side panels, but they need a bunch of paint work. Rust starting.
J-Mech 05-23-2015 12:11 PM
Originally Posted by Oak (Post 329633)
This machine should have the "maintenance minder" type hour meter so I'm thinking the hours are not correct.
I agree. Looks like someone robbed a meter out of something else and stuck in it.
snoel 05-23-2015 01:22 PM
That may be. But, the travel control linkages, and steering gear, etc. show a lot of wear. But, not more than I expected, with the images posted on CL. And, not really a problem, just opportunity, to stay busy, ...and spend some more money.
J-Mech 05-23-2015 02:19 PM
I understand it's wore out, but 4000 hours is not likely at all. Not unless it's on motor 3 or 4..... or 5. Bare min 3. The twins average life is around 1200-1800 hours.
snoel 05-26-2015 02:45 PM
3 Attachment(s)
Seat was too tall, so returned it , and got this one. Much better.
Attachment 65573
And pulled fender to address the trunion.
Decided to do the quick fix, stop the speed surging, on both the 782 and 169. Feels like a gear drive, now. Constant speed with changing load. Just need to learn to "feather the speed control, much the same as a clutch. Not elegant, but it is mine and I like it.
snoel 08-01-2015 12:14 PM
Today, I replaced the failing tie-rod ends. Two failed, so I replaced all four. Tightened the axle pivot bolt nut to remove excess "slack", and adjusted the toe-in, and left-right turning radius equality. Drives much better.
Note: I really like the twin engine, for the light work, around the place.
