If its a Husqvarna then its probably a foot operated hydro not lever. Check all the linkages from the foot pedals to the hydro. I think a possibility is the mount or bolt that makes the foot pedal rock back and forth might be worn possibly? Or maybe one of the links are messed up.
Okay, rechecked everything mentioned, even replaced the drive belt.....No change.
I figured the drive belt wouldn't have anything to do with it. How could it? It drives the rear, in the same direction, regardless if in the forward or reverse direction... But tried it anyway. The rear drive checked out fine after I removed the belt, no sloppiness, it feels tight as should be. All the linkage is normal...... Next:bigthink: |
Is the relief valve fully engaged? Maybe its like an 8th out?
Ok. I'd check to see if the slider is moving all the way back and forth.
As I said earlier, all linkage is normal, and is fine..... Thanks |
Sounds like she needs a belly mower for her cub. :biggrin2:
Todd I was doing some looking and people say most hydros have an adjustment that makes it go in all forward or all reverse, and if in the middle it will go in both. Maybe yours has it too somewhere? Also I found this: http://www.tractorforum.com/f154/hus...d-27649-print/
| All times are GMT -4. The time now is 08:17 PM. |
