That looks awesome! Wish I could've got to that IH auction, still hearing from folks of the great deals there, it was only 20 miles from where I live but I was far away from home at the time.
ccguy,
Its looking great... I really like the red tractors.. I used to go to the IH dealer with dad in the early 80's... they kept a showroom full of Cub Cadets.. I still remember when they went red... I fell in love! I used to beg dad for a "Red" cub... he said we had to wear the yellow 1450 out first! Little did I know it we could never wear the 1450 out.. Mom still uses it weekly!! A good friend and neighbor bought a new 782 in 1980.. I sat on it at the IH dealer in the showroom... we now own that very tractor! As always your work and attention to detail is second to none! Keep us posted! :beerchug: :American Flag 1: |
3 Attachment(s)
Thanks gentlemen for the kind comments.
I would have loved to visit an IH dealer in their heyday. Between equipment of all sizes, implements, parts, service, lubrication, trucks and trailers, refrigerators and freezers, I'll bet they were a very busy place in town. Drained the old Hytran and removed the filter. This machine with a SLOW leak at the pump gasket -- fluid was clear but only drained +2 quarts. Always change the trans fluid on a new-to-you machine. New CaseIH gasket, back-strike plate holes, Ultra Gray around the bottom three holes/bolts (always give me problems) and done. Will leave the housing empty of fluid until after I change the cork gasket - which is next (waiting for a warm weekend). Debating of whether to replace the rag disks...no tears or cracks but they are 35 years old. |
It would be hard to decide on the rag joints... but I sure would be tempted to change them while I was there... but then again I'm not convinced that the "new" rubber is of the same quality that is was 30 to 40 years ago.. seems most of the modern rubber parts I get deteriorate quickly nowdays.
Looking good as always! What kind of rear tires are those? I really like the looks of them! :beerchug: |
cub
Hey CCguy, what kind of axles are in there? Coarse or fine spline, looks like it has the thicker carrier. Mike
Course splines. Tractor was assembled 1st week of January, 1982.
That's what is so crazy about these rag joints...they looked like they were dipped in rubber. Granted they are all twisted but I'm thinking what if the new ones don't hold up and don't last more than a few years...and these I've thrown away! I don't know... I wanted an aggressive tire for winter and Ags would create lawn havoc with all the wet weather we have up here. I went with Carlisle All Trails (amazon @ $93. with free shipping!). Made in USA, 4 ply and very aggressive. I've got 25 lbs. in them and when the warm weather gets here, I'll bring them down to 15. They were pancaked in transit so I don't want to break the beads. They will flatten out when they get to the correct pressure. Hard to install even with vegetable oil. Excellent ratings and perfect for rough terrain or service where it's carrying a lot of weight. I looked at Kenda K502's Terra Tracs which were much less expensive but I went American. |
Tires look great.. kind of gives it a distinct look.. They should give good traction in all kind of different conditions.. I'd load them with fluid and drop them to about 10 psi... It makes a huge difference with traction even just mowing grass.. We found out years ago that loaded tires are much more kind to the turf. :beerchug:
THANK YOU FOR GOING USA!! :American Flag 1: |
12 Attachment(s)
"Splittin" the Tractor
The beauty of the 682 is its simplicity and ease of working on it without having to circumnavigate all the plumbing of a machine with hydraulics (I know, forget winter plowing...). Now, had I known that I had a small (sneaky) leak with the cork gasket on the pump, I would have addressed that before all the painting and tin work. So, with the Hytran fluid drained, the seat, fenders and tunnel cover removed, next came the battery holder, wiring and solenoid. Detached the brake spring, brake return linkage, speed control rod and brake linkage with the two cotter pins. When attempting this, I used a safety strap (to strap the heavy housing to the jack to keep it on the jack and from damage - to me and it) jack stands (for the frame) and a floor jack to help in removing the transaxle. I removed the 4 sets of bolts/washers/nuts from the flexible (rag) joint connecting the drive shaft to pump. Next was removing the 6 hex bolts attaching the transmission housing to the frame. Using the jack, I slid the transmission/axle out through rear of frame. Lastly, loosened/detached both ends of the transmission suction tube and then removed the 4 hex bolts that attach the pump to the case. In prepping the new gasket, I used carb cleaner to clean everything up and dry it off. I also had access to cleaning all the rest of the crud off from around the pump and the front of the transaxle. Then I broke all the rules and used Permatex Ultra Gray for hopefully, added longevity. My Expansion plug was leaking (even without fluid inside the case when it was apart!) so I pried the plug out with a mini screwdriver, cleaned off the old sealant and used a little Ultra Gray to reseal. Replaced the rag joints and back together she went. Big thanks to yeeter, Roland, Gerry Ide and Charlie Proctor. Now I just hope it works! |
Looks like top notch work to me!! Should work great! :beerchug::beerchug:
I agree... the tractors without hydraulics sure are easier!! :biggrin2: |
I like the tires.
| All times are GMT -4. The time now is 03:40 AM. |
