-   Welcome to OnlyCubCadets (https://www.onlycubcadets.net/forum/forumdisplay.php?f=2)
-   -   Hello (https://www.onlycubcadets.net/forum/showthread.php?t=50876)
V30crewcab 12-18-2017 08:16 PM
1864 is a nice machine.
DieselDoctor 12-18-2017 10:20 PM
Welcome aboard Marko. There are many good options/combos available to do your chores. I'll agree that the 129, 149, 169 series Cubs are a great way to get into the hobby and you'll have a good durable tractor with many options. When you spot a tractor or implement you might be interested in let us know and we can help you decide if it is a good choice. You may find that you'll want more than one Cub, most of us have several. (at least!)
J-Mech 12-19-2017 12:14 AM
Originally Posted by Marko141 (Post 441284)
Might end up with an 1864, wheel weights, chains, 2 stage blower all ready to go. Still need to find a tiller though.
If you get an 1864, you cannot put an IH tiller on it unless it has a rear cat 0 3pt, and you buy an adapter to install it. Then, you will only be able to use the #2B tiller.
If it doesn't have 3pt, you will have to buy one, and an adapter OR buy the later model CCC built model 400 tiller.
Both these options are expensive.
I have designed an adapter for the aluminum rear ends so that you can run an IH tiller on them without having to have the cat 0 3pt and the adapter. But you will still have to install a sleeve hitch, and I do not know how that would work on an 1864, as I have not seen it done that I can recall.
I suggest looking for an IH built tractor or at least one with a CI rear end if you want to run a tiller.
Marko141 12-20-2017 12:40 PM
Well I guess I'll have to do what you guys suggest and get 2 tractors then! One for tilling and one for the snow. I really do like the older look of those 129 and 149 tractors. And just like you guys have multiple cub cadets my interest was into golf carts before this. My big cart has a 23hp vanguard in it with billet pushrods, huge cam, bigger starter, and rev kit. She hits 45mph with a 25" tire and 7" double a arm lift. It's a remarkable machine.
Marko141 12-20-2017 01:12 PM
2 Attachment(s)
This and put up a phot or 2, give it a test
RobSeidel 12-21-2017 11:45 AM
Hello and welcome, Marko!
jbrewer 12-21-2017 08:21 PM
Originally Posted by Marko141 (Post 441439)
Well I guess I'll have to do what you guys suggest and get 2 tractors then! .
You'll fit right in here !!!:beer2:
olds45512 12-22-2017 09:38 AM
4 tractors is really the minimum. One for mowing, one for plowing, one for a snowblower and one for the tiller.:biggrin2:
DeltaCub 12-22-2017 09:48 AM
You also need one for storing stuff on the hood and seat, one just to be in your way, one for "I don't have any immediate plans for it....but it was a deal" and one that leaks oil!:beer2:
jbrewer 12-22-2017 10:18 AM
Then of course , one always needs a project to work on!
