-   -   582 not so quick fix up (https://www.onlycubcadets.net/forum/showthread.php?t=32395)
TIMCRUTCHER 06-07-2014 07:02 PM
I put the bottom spindle seal in backwards so that if it is over greased it does not blw the seal. Dealer told me to do that.
Sam Mac 06-07-2014 07:24 PM
Yep, one of them needs to be in backwards to allow the old grease to be pushed out. This had both facing in. :bash2:
Some people should not be allowed to use tools. :biggrin2:
Shrewcub 06-07-2014 10:06 PM
Originally Posted by Sam Mac (Post 265668)
Got the old turd running. Bad head gasket, but the engine is pretty well used up as is the clutch. Had to re-build his "Good deck" Yeah love it when someone leaves the spacer between the spindle bearings out. Sharpened the blades put them back on and couldn't turn the spindle, seals were in upside down, idler pulley seized up solid and on and on and on. It runs, it cuts grass. I did what I told him I would do. Big thanks to all of you that have helped in this project. Give yourselves a pat on the back.
Glad you got it going Sam! Feels good to help someone out.
:IH Trusted Hand:
Nitro 06-08-2014 09:48 AM
Good man, Sam. Giving is rarely painless.
Sam Mac 06-19-2014 06:49 AM
Originally Posted by Sam Mac (Post 265535)
No idea why it only had 1 tire chain on it. Also found the kill wire had been eaten by the mice. Just shoot me now. If this was my tractor I'd have the cutting torch out and fired up.
Forgot to post the pic of the wire the mice had eaten so here it is.
