-   -   CCC built 82 series Kohler swap (https://www.onlycubcadets.net/forum/showthread.php?t=53441)
Gompers 10-01-2018 01:03 PM
Originally Posted by Mudrig150 (Post 468036)
I'm mainly doing it to allow for more engine movement and to allow for more flexibility if I want to swap in something bigger. Also it'll be way easier pulling the engine of transmission, and I won't have to worry about roll pins breaking or the whole driveshaft destroying the hydro lift..
IH put a 20hp engine in there with rag joints. It’ll be fine if you use good parts. Especially with a 12hp up there
Originally Posted by Mudrig150 (Post 468041)
It's in the works. How am I supposed to work on something I don't even have yet?
Edit: Looking back, you guys mentioned that the Pto is different. If it's a 1282 would the whole PTO or just the pulley be different? If it's just the pulley, could you swap them? I don't see why not.
It’s probably just the pulley. I don’t know. Haven’t done one.
Mudrig150 10-01-2018 01:29 PM
Seems like the whole PTO is different. They do look like a bolt-up connection which will be nice.
Mudrig150 10-01-2018 01:31 PM
Originally Posted by olds45512 (Post 468056)
I have a grille but no headlight panel.
That's fine by me, the headlight panel is for sure way easier to find than the grille. Do you have both parts of the grille?
olds45512 10-01-2018 01:35 PM
Not sure what you mean. There's a lower grille which I have and the upper grille which is the headlight panel which I do not have.
Mudrig150 10-01-2018 01:38 PM
I thought there was a mesh part and the bar part of the grille? All the part diagrams list the grille as two separate parts not counting the headlight panel.
https://polr.partstree.com/v1/iplima...O2k6MTAwMDt9fQ
olds45512 10-01-2018 01:43 PM
I have never seen a tractor with that mesh part so I don't have it.
Mudrig150 10-01-2018 01:44 PM
Fine by me.
Edit: Me, being an idiot just realized that to do the hydro lift swap I'll need to swap the dash, add that to the list of parts...
Gompers 10-01-2018 01:49 PM
That mesh part was removed on later tractors and was only on very early 82 series tractors. It ended up getting plugged a lot and causing overheating so ih came out with a grille improvement package that replaced the insert and screen with a different insert that had additional black bars in it.
Mudrig150 10-01-2018 01:51 PM
Oh, that makes sense. Well I'll be fine anyways.
olds45512 10-01-2018 01:54 PM
Originally Posted by Mudrig150 (Post 468067)
Fine by me.
You don't need to switch the dash. The metal part already has the hole for the lever so all you need to do is cut the hole in the plastic part which is easy to do it you trace the hole off the metal part.
