Sure it does. I've done it many times. Most of the time now I don't even plow a garden I just run a tiller. I've had disks I've pulled around with the cubs and they don't do much besides just ride over the clumps. Start weighting it down and the tractor wouldn't pull it without spinning. I sold the brinly double ganger I had. It was cool but I never used it. I've also used the bigger krause 32ft disks and they worked okay but they also have some weight behind them to really cut in! |
The angle part is true...i remember pulling a 10' er around on an old minnie moe when i was a kid that you actually had to hand crank into ><!! what a pain in the A#$ that was!!! Thing was probably 100yrs old back then, and i remember getting tired and being like, "ok good enough", and it wouldnt do shit....get back off, crank some more...then back to parallel, thats how it was transported, before hydraulics, and probably rubber!!!
Just stating I'm not a fan of disks. I'd rather have a field cultivator with a leveling bar of some sorts |
angle is no substitute for weight, daddy had a set of harrows for his GT, I pulled it with no weight it wouldn't even go deep enough to cover a pea !! Added some weight to it it still wouldn't roll dirt lol. I need a miniature set of Taylor-way harrows or a offset harrow. I guess getting it to work to your expectations would only be possible after setting it up as a double gang ? Have you tried the harrow (just one set) yet if so does it work ?
I know I'm aging myself here, but back before all this modern day farming came about, to prepare a field we would start out with a disc to break open the soil. The idea of disc-in first was so when you came in with the plow it rolled the soil over better and there weren't big chunks.
We would first go length ways then the short way. From there we would plow the field with a five bottom on the 856, then disc the field again length ways to level it and fill in the dead furrows, and then the short way. Follow that up with the drag, long, short, long way and your field was prepared for planting. I know you young guys think that's a lot of "farting around" but it made one beautiful, smooth field. Sure it was time consuming, but that was OK, because I was making $1.50 an hour:biggrin2: I still think a disc is all about the set up more so then weight. :TwoCents: |
Listen guys I've ran way too much equipment for too many years to argue about this. Disks work. It's all about the setting. I'm confident this little disk will work, the question I have, is once I get it set up to do it's job, will I be able to pull it. Quote:
2 Attachment(s)
I also agree a disc is a great tillage tool. My buddy and I have a tillage business we do on the side prior to our full time jobs and we use this tandem disc setup when there are huge chunks from when we mold board plowed a garden and the IH rear mounted tiller wants to till uneven caused by the tractor driving over big chunks of soil or sod. It does a fantastic job of filling in furrows and leveling but I do put blocks on it just so the disc busts up dirt clods instead of riding over them and to cut sod if it's a fresh garden we just put in but setup has a major play in how it cuts also. It does a great job cutting up old foliage in gardens from previous season prior to plowing it. I also have used a field cultivator to breakup the first inch or 2 of topsoil which is a great tool also. I have no problem pulling the tandem disc even with a harrow behind it with the 982 but i enjoy the seat time. This pic is taken after I disked down mold board plowed ground before tiller ran across garden. I know the garden is damp but customer wanted it done.
