-   -   April showers bring May.....................O's? (https://www.onlycubcadets.net/forum/showthread.php?t=32138)
Alvy 04-03-2015 10:51 PM
Welded nut to frame for steer axle mount since hole was very elongated
Attachment 63682
Alvy 04-03-2015 10:52 PM
Attachment 63683
Engine and misc pieces primed
Alvy 04-03-2015 10:55 PM
Attachment 63684
Rebuilt the clutch with new spring and all bearings and bushings
Alvy 04-03-2015 10:56 PM
Attachment 63685
Got some assembly done, it's coming a long. I used the usual school bus yellow from tsc with hardener and reducer in my new Cheapy HF hvlp gun but it seems to do well. I also for the first time got the Napa martin senior white paint but I think they mixed it wrong as it's more almond to me than it should be for this serial range. I'm bummed out about it but oh well at least it will be uniform. I gave them the paint code and everything from our site and they said it crossed and I could have my choice of two different levels, I chose the industrial finish or whatever they called it, came pre thinned and everything, just had to add hardener. Learned something too, martin senior is a division of sherwin Williams, did not know that.
Alvy 04-03-2015 10:58 PM
Attachment 63686
Redneck paint booth!
darkminion_17 04-03-2015 11:00 PM
Moving right along.did you sandblast the S/G?
Alvy 04-03-2015 11:03 PM
Thanks buddy. Yes see pic in post #30 ghost edition. I jammed some wadding in the oiler caps
Alvy 04-03-2015 11:07 PM
Still need to get some new tires
Attachment 63687
darkminion_17 04-03-2015 11:10 PM
I would take it apart and check it anyway,there is no gasket on the end cap.
I like painting outside also,plenty of light.
Alvy 04-03-2015 11:19 PM
Yeah that's probably a good idea I forgot about that actually for both ends. Surprisingly there wasn't any sand that got in the engine or transmission, it made easy work when I got it apart to just focus on the paint removal where the blaster couldn't get. I'm a fan of doing it this way and might do the next one the same who knows.
