-   -   I was looking for a parts tractor... (https://www.onlycubcadets.net/forum/showthread.php?t=54085)
john hall 01-06-2019 10:05 AM
Originally Posted by sorner (Post 475579)
Ewww. Looks like I’ll be hitting up Jeff for some parts.
30+ year old drivelines--does anyone ever run across one that doesn't need complete rebuilding? At least its one of those repairs when its fixed, you can normally forget about ever needing to do it again.
sorner 01-06-2019 10:07 AM
Yup. More like 50 years in this case.
DieselDoctor 01-06-2019 04:29 PM
Looks like you're having fun Steve. If it was all done up and for sale you probably wouldn't have bought it, right? The repairs and the sense of completion are the fun part. A new shaft from Jeff and it will be good for another 40+ years!
jbrewer 01-07-2019 07:53 AM
Hard to get more than 50 yrs out of a garden tractor! I tell you , quality is going downhill
sorner 01-09-2019 11:10 AM
So, I can easily obtain a replacement shaft for this. But another problem I have is the fan is completely devoured, I guess from the wobble of the shaft, and the limited clearance in the fan shroud? I'll need to replace that fan too.
I'm thinking about doing something different, like a cyclops CV style shaft upgrade. Has this ever been done? I would probably have to have it modified to fit, I already have a fan for one. I would just need to locate a shaft, and probably remove the fan shroud.
Rmowl 01-09-2019 12:02 PM
I’ve got several good shafts with fans. Also have a shaft from an 1861 should you want to go that route, I’d stick with the original setup.
sorner 01-09-2019 12:17 PM
Probably is best, as others have said and I tend to agree... that original setup has lasted a long time.
Leadslingingdaddy 01-09-2019 12:39 PM
JB Weld it!!! Let us know how long it lasts!! lol
sorner 01-09-2019 11:37 PM
I got the hitch on it tonight. Now I just need to get the driveline in order and the ag tires on the back, and I’m ready for spring.
Attachment 97839
sorner 01-11-2019 03:42 PM
3 Attachment(s)
Here's the driveshaft... I think the shaft coupler for the hydro end is usable and doesn't need replaced. The hole is still good.
Attachment 97869
Attachment 97870
Attachment 97871
