Weichai torch technology co.,ltd Weichai torch technology co.,ltd is the largest spark plug manufacturer in China with longest history. Torch brand spark plugs have 21 lines and more than 200 models which are widely applied for automotives, motorcycles, small gasoline engines. https://m.en.weichai.com Weichai Torch Technology Co., Ltd. Cross Reference:. https://www.sparkplug-crossreference...rt/torch/F6RTC |
For the spark plug, a Champion RN10Y, or NGK BPR6ES. You want a hot spark plug for a colder engine to prevent fouling. |
The issue with low sections of the fuel system are fuel vaporization. The vapor pressure of modern fuels is - junk. The vapor pressure of hot fuel is worse. the vapor pressure of hot, Ethanol fuel is abysmal. Now, we're not talking about drawing a lot of fuel, over a long distance, at a great height, but with the fuel just above a running engine, and the fuel line passing right next to the exhaust, best to avoid the fuel vaporization issue completely. Now, if we want to use 100 Octane avgas, with a very high Reid vapor pressure, we could wrap the fuel line around the axles, and it would never have a problem. Ethanol blended fuel - well, no guarantees. |
