Hand crank tilt dump cart
Just got a cart for free from a friend. Not sure what brand it is or what year. It appears that the tag was removed.
http://justsomepics.smugmug.com/Hobb...70_54roq-M.jpg http://justsomepics.smugmug.com/Hobb...09_o3YLZ-L.jpg http://justsomepics.smugmug.com/Hobb...56_QKgtj-L.jpg Thoughts??? |
Did it happen to come with the yellow and white Sears tractor. As soon as I saw the cart I immediately thought it was a sears due to the triangular shaped toungue in stead of the normal straight. I've never seen a hand crank on a dump cart before so maybe this is a top of the line luxury cart.
On front lower panel of the cart, it looks like you can see where the tag was. Measure that spot, and maybe even rivot hole to rivot hole, and compare it to the serial tag on the Sears tractor which should be by the gear shifter. Here is a link to a pic of a Sears trailer that is prob the same but without the crank. http://www.vintagesearsgardentractor...3_dumpcart.jpg Good luck |
No, but this was the haul. Im gonna head over there and see if I can find the rear end to this.
http://justsomepics.smugmug.com/Hobb...54_kDjyt-L.jpg |
Nice haul!!! Love the sickle mower. I've got two. Getting hard to find. I'd love to get hold of that roti-tiller. Still looking for one. Nice haul!
Dang you ended up with a great hual!
I like the trailer. Can you crank it up and get some pics of the mechanism? Thought of doing something similar to a trailer I have. Great haul on everything.
KennyP |
I thought that the trailer was cub due to the color similarity to the 120s and up. Yellowish white, anyways could not find any identification.
I will try to get those pics for you 108cubber this weekend, if not first of next. Im debating if I want to convert the handcrank to a electric crank...??? not sure, but I will refinish it this fall before the big haul. |
| All times are GMT -4. The time now is 10:40 AM. |
