-   -   help with 128 (https://www.onlycubcadets.net/forum/showthread.php?t=10072)
green 4 acres 04-15-2011 01:08 AM
help with 128
I need with couple of questions my 128 has what I think are lift arm holes /bushings high on the tail of the frame , are/were these used for a 3 pt lift arms or does the hitch pictured on the main forum fit this model ?
any advise on freeing up a lift lever lock button ( top) its been soaking in penatant trying to separate the arm from pivot today I have a oxy/act torch wish I had a exploded view
the lever on the other side is for ?
jeff k. 04-15-2011 09:32 AM
Check here.
http://www.cubcadet.com/webapp/wcs/s...0Cadet%20Parts
red211 04-15-2011 10:29 AM
PTO is the lever on the other side. A little PB got mine loosed up, but it was not stuck to bad. Good luck on the parts look up, if your like me you'll need it. A pic of the holes/bushings will help the experts here tell what you have.
