Throttle Shaft Bushing Part Number for those that might need it.
I decided to remove the throttle shaft on my 128's carb and get it tightened up. I went to Ace Hardware who carries Hillman products and talked with the Hillman representative that works at that store. He told me they had the bushings but that they now carried them in Servalite brand name. Hillman bought out Servalite.
The bushing fits perfectly and you do not have to drill your carb body. It removed all looseness in the throttle shaft. Also adding that the butterfly screw size is: 3-48 x 7/32" A 3-48 x 1/4" works fine. The Servalite part number is: ST814-2 They were about .80/each Size is 7/16"x1/4"x1/16" Here is the bushing: http://i210.photobucket.com/albums/b...b/Image001.jpg The first bushing in place to be seated: http://i210.photobucket.com/albums/b...b/Image002.jpg I used two bushings and a 6mm socket to seat them. Very very easy to do.: http://i210.photobucket.com/albums/b...b/Image003.jpg Hope this is of some help. |
There is no old bushing. The carb body wears out after years of use around the throttle shaft causing it to wobble and become loose and normally making the engine surge or not run smooth. These fit right into the body with no modifications. :beerchug:
I was wondering of this info could be added to the tractor technical section?
Adding also that the butterfly screw size is: 3-48 x 7/32" A 1/4" works fine. |
The dimensions for the "N" throttle shaft bushing are OD ~.400" ID ~ .215" Thickness ~ .100" I'll go see if I can find a standard thrust washer to fit this John |
Is this the correct bushing from Fastenal?
http://www.fastenal.com/web/products...ex?sku=0435459 |
That would be it. :beerchug:
Thank you for this detailed information. It'll help me get the throttle shaft fixed on my 123!
| All times are GMT -4. The time now is 04:55 AM. |
