The Beast Has Landed
Well its home.....and its super heavy. My Buddy came over and helped me move it into place. I have a few questions, I will list by picture, thanks for any help in advance.
http://jlefantephoto.smugmug.com/Mac...dsc_6806-M.jpg ok, the pump head has no unloaders........the tube that connects on the right of this switch runs to one of the tubes that goes into the tank off the pump..... http://jlefantephoto.smugmug.com/Mac...dsc_6812-M.jpg see it all the way on right... http://jlefantephoto.smugmug.com/Mac...dsc_6809-M.jpg the other spot on it, is not connected to anything.....I assume this is a unloader, maybe with a check valve? Not sure HELP !! http://jlefantephoto.smugmug.com/Mac...dsc_6801-M.jpg Anyone know what any of this means? http://jlefantephoto.smugmug.com/Mac...dsc_6811-M.jpg |
I believe that is the pressure switch. Not sure of the open ended line, if not to pick up reference atmospheric pressure. The tag on the tank is from manufacturer of the tank certifying that it can withstand 150psi continuous, and 250 psi max temporary, as of 1945. I Wouldn't test that now!!!!!! Tank looks pretty bad from outside view, and who knows what it is like on inside. Remember, that compressed air holds water better than tupperware, so the inside of that tank has seen more water than you would think of since 1945. :bigthink:
used
I figured out the piping on it, there is a check valve under the line into the tank and it goes to the pressure switch unloader. I want to get a new pressure switch with unloader and an on off switch. |
great thing that it was dry! check out mscdirect.com or mcmaster.com or grainger.com for a pressure switch. anything pneumatic commercial you could find easily! :beerchug:
check yours out, might just need some tinkering. |
Getting
I am defiantly going to replace the pressure switch and new blow off valve. I just want to wire it up and make sure everything else works ok before I drop money on parts. It's like anything else previous owner says yeah it's perfect until you fire it up and it don't work haha.
beast work
ok made some compressor progress, there is no site glass how do i fill oil?
easy drain..... http://jlefantephoto.smugmug.com/Mac.../M/drain-M.jpg crankcase tube http://jlefantephoto.smugmug.com/Mac...0/M/tube-M.jpg new pressure switch and saftey valve http://jlefantephoto.smugmug.com/Mac...M/switch-M.jpg |
working !!!
Well after I put the new switch on, I added a 220 line in my garage and rewired the motor on the compressor to the new switch. It now works as expected and is very quiet. Holds air great with no leaks and drained a few times with no oil or moisture in the tank !!!!
http://jlefantephoto.smugmug.com/Mac...7_5rdz8kk-A-LB |
