-   -   Lower 3pt Hitch Bracket (https://www.onlycubcadets.net/forum/showthread.php?t=10394)
spanishsilver 04-26-2011 10:40 AM
Could someone tell me which bracket I need for the inside of the tiller gearbox mounting frame. I am missing the bracket that goes on the inside of the the frame. Ordered one last week but the 3 holes on bracket wont line up with gearbox mounting bracket. Gearbox bracket has 2 holes and part I ordered has three holes on each side. This is for a 1650 and 1a tiller. Any pics of your lower bracket set up would be great. Thanks have a great day.
_DX3_ 04-26-2011 12:23 PM
You need the standard 2 point mount that comes with the sleeve hitch lift system:
http://i210.photobucket.com/albums/b...Image002-1.jpg
_DX3_ 04-26-2011 12:24 PM
Here is a PDF of a manual for the tiller. Should help you out with the mounting and adjusting.
http://ccmanuals.info/pdf/1A%20Tille...s%20Manual.pdf
spanishsilver 04-26-2011 12:45 PM
That is the bracket I got from cc specialties. Mounting holes for differential line up but the 3 holes on the side dont even come close to lining up with gearbox bracket. Could it be the wrong bracket because i was told the bracket i was sent is a universal bracket. Also he mentioned there was an older style. If anyone has one they want to sell let me know. Thanks
_DX3_ 04-26-2011 12:58 PM
It may be wrong if it is a universal. Call them back, they may swap out with you.
jeff k. 04-26-2011 03:51 PM
Can you post a pic of the one you have?
spanishsilver 04-26-2011 04:25 PM
Will do jeff bit i dont get home until friday. The brackey i have has 4 different mounting hole to mount to diff also has one slotted towards the middle for adjusting bracket up and down. Ill try to have my kid take a pic.
JayBrd 04-26-2011 04:54 PM
That sounds like one of extreme motorworks lower brackets. (although you may not have the "ears" on yours)
http://ccspecialties.org/4holebracket.JPG
spanishsilver 04-26-2011 06:41 PM
That is it jay but no outside bracket. Is that why its not fitting. Thanks
spanishsilver 04-26-2011 06:57 PM
Here is the one i have jay. Cc-29-101 from extreme motorworks.
