check out my new puller!
http://www.youtube.com/watch?v=o3So0fRwuf4
this is my mower!! if u wanna subscribe to me my channel is austinboy85 feel free!! browse through the videos too!! be shure to like and subscribe thanks! |
Great transformation... Will have to get us a vid of it pullin'..:beerchug:
i will have to try but i still have a few things to work out !! once it runs for two minutes even though it puts and sputters it will not start and stay runiningagain until it cools for an hour or two or over night !! it dont smoke !! but ive completely cleaned the card and im still havening problems can somone help me out?
Kinda sounds like either the float is not set properly or there's a piece of junk in the needle valve causing it to take forever to fill up the bowl. I don't think it would get hot enough in two minutes to cause any issues to come up.
ive cleaned out that whole card three times ! very good to thorough clean with carb and throttle body cleaner !! any other suggestions !
I beleive your ignition coil is faulty. Ensure the condenser is working and hooked up. You should have a blue spark. If not, either your coil or condenser is faulty. I have not yet looked at the vid so I'm not sure if you replaced those parts.
Something else to check is the screen inside the fuel tank. You will have to pull the tank out, and carefully remove the nipple going through the seal in the tank. The screen is just on the other side of the seal and attached to the nipple.
| All times are GMT -4. The time now is 05:50 AM. |
