-   -   Easy Out - LOL (https://www.onlycubcadets.net/forum/showthread.php?t=12459)
CC1650Dave 08-01-2011 11:53 PM
Easy Out - LOL
Has anyone ever had any success with these things?
I've used them twice, and both times they broke off in the screw I was trying to remove, making the job twice as hard after they broke.
Tonight I was trying to back out a rusted license plate screw from my Lexus. I drilled the hole and put the "easy out" in there. Turned it ever so gently (since I'd broken one off before trying to remove a broken muffler screw from my weed wacker) and yep, it broke off in the hole.
Now you can't drill anymore, because I think these things are harder than a drill bit. I had to go in to the backside and remove the welded nut that held it all in place.
I'll never use one of these things again.
scleve 08-02-2011 01:07 AM
Most of the better brands will hold up good. I had the same luck with off brands. I always use the largest size I can and still soak with PB Blaster.
Rales 08-03-2011 02:40 PM
I have had some luck with easy outs but more often then not I break them. I have totaly given up on them and will slowly drill out a bolt untill it falls apart inside. If its done right and you have some luck you wont hurt the threads that are there. Depending on the area if you can drill it out, heat up the whole area then put something cold on whats left of the bolt, sometimes the shock will let it come loose very easily.
scleve 08-03-2011 03:41 PM
Yeah like heating a bearing and freezing the shaft for a press fit.
jkier 08-03-2011 05:18 PM
I usually end up using reverse twist drill bits.
If they don't come out while drilling they usually loosen enough for the ez-outs
