HELP!!!!!!!!!!!!!!!! CUB 3184
CAN ANYONE OUT THERE HELP ME? I HAVE A DRIVE SHAFT STYLE MOWER DECK, BUT I CANNOT SEEM TO KEEP THE ENGINE BELT ON, IT SEEMS THE MORE I USE THE PTO, THE MORE IT COMES OFF, AND I HAVE THE 2 BOTTOM GUIDE BOLTS TO GUIDE IT TO KEEP IT ON, BUT THE BELT STILL SOMEHOW SEEMS TO SLIP THROUGH, THE BELT IS ONLY 2 YEARS OLD, ANY THOUGHTS WOULD BE APPRECIATED, THANKS:bash:
First check and make sure the bottom pully is not loose, I belive all that hold it in place is a C-clip or a snap ring.
Make sure the bottom pully is not bent. If every things checks out you might need new belts as they do wear out. I end up replaceing my belts on my 3235 every other year and I only use my tractor for snow removal and tilling the garden, I do not mow with it as I dont have a deck for it. |
| All times are GMT -4. The time now is 01:47 PM. |
