-   -   48 inch deck rebuild (https://www.onlycubcadets.net/forum/showthread.php?t=14156)
bsyphrit 11-05-2011 06:04 PM
6 Attachment(s)
I got this deck at least 10 years ago with the intentions of cannibalizing it for parts but after getting it home it looked to usable to do that so i slid it on and have been using it ever since. If i want to keep it going it is time to give some much needed attention
Attachment 16921
Attachment 16922
Attachment 16923
Attachment 16924
Attachment 16925
Attachment 16926
Diz Jr. 11-05-2011 06:32 PM
Glad to see you are giving the deck a makeover :beerchug:
I have patched mine up once already :biggrin2:
bsyphrit 11-06-2011 04:40 PM
3 Attachment(s)
price on the deck reduild just went up. i took apart the splindles which all spin freely and after cleaning the bearing up i decicded to change everything out.Attachment 16981
Attachment 16982
Attachment 16983
new bearings and seals are on order and this will give me a chance to work on the deck itself, am finding it to be severly pitted and thin in spots. time to put my new used mig to work and see if i remember how to use one. been little over 30 years since i used a mig at school. :bigthink:
bsyphrit 11-12-2011 09:29 PM
4 Attachment(s)
got all or as much welding done on the deck, metal was pitted so bad i decided to stop the rust with a coating of phosphoric acid, i read it acts like bluing on a gun and is paintable.after this next i will coat the underside with fiberglass resin to seal it. Attachment 17247
Attachment 17248
Attachment 17250
Attachment 17251
Diz Jr. 11-13-2011 08:39 AM
bsyphrit
How did the welding go?
Those bearings sure are pitted :bigeyes:
It ought to be a lot quieter now.
bsyphrit 11-18-2011 05:22 PM
7 Attachment(s)
well bearings and seals are on order, in the mean time i decided to coat the inside of the deck with fiberglass resin. i think it did well at giving it a smooth surface to work with so grass and debris will not collect so much also got 98% of the wire brushing and prep work done. i also decided to redo an extra spindle to have on hand as a backup, had an extra cast nose piece that was not chipped like the original and pulley to have. while i have every thing set up may as well paint every thing i have to be ready to put it into service
welding went well but boy did i have to use the wire to make it the way i wanted, it is a solid shell now but i bet i used 3/4 of a 2 pound spool to make it that way
Attachment 17491
Attachment 17492
Attachment 17493
Attachment 17494
Attachment 17495
Attachment 17496
Attachment 17497
Methos 11-19-2011 10:06 AM
Sweet pics! Your deck is coming along great!
CADplans 11-19-2011 12:38 PM
"but i bet i used 3/4 of a 2 pound spool to make it that way"
I ain't happy unless I get to weld a couple pounds of rod a week!!
Go back and hit it with some more weld!!
:biggrin2:
Looks good, now we need to see some clippings spray!!
Diz Jr. 11-19-2011 07:15 PM
Nice work bsyphrit :ThumbsUp:
ACecil 11-19-2011 10:15 PM
I totally agree! :beerchug:
