-   -   hour meter on/off? (https://www.onlycubcadets.net/forum/showthread.php?t=1446)
papaglide 08-25-2009 06:56 PM
hour meter on/off?
Alright, here is my problem: the hour meter on my 1862 only works when the PTO is off. When the PTO is on, the hour meter doesn't spin. Anyone have any idea why cause I sure as heck don't.:bigthink:
Merk 08-25-2009 08:04 PM
Is the wiring correct?
papaglide 08-25-2009 08:34 PM
Merk, I wouldn't know where to start with the wiring. What I can tell you is that the PO disconnected the PTO off/reverse clip and the engine off clip from under the seat. The PO put a jumper wire in the PTO clip that enables it to stay on. I think I just described that correctly, hopefully.
Merk 08-25-2009 08:54 PM
Sounds like you need a wire diagram for your Cub.
I don't have a link to a wire diagram for your 1862.
Hopefully someone can post a link.
Carl_NH 08-25-2009 09:55 PM
1862 Wire Diagram
Diagram for 1862 is here
http://i176.photobucket.com/albums/w...ts/1-1862A.jpg
papaglide 08-26-2009 12:46 AM
I'll check that out tomorrow. Thanks Carl!:beerchug:
