-   -   Cat-0 for my 582 (finally...) (https://www.onlycubcadets.net/forum/showthread.php?t=15240)
Matt G. 01-07-2012 11:07 PM
5 Attachment(s)
After having it designed for 5 years and slowly collecting all of the parts, I finally got around to at least starting to build a Cat-0 3-point for my 582 while I was back at home between Christmas and New Years. I'm trying to correct a couple of shortcomings in the original design, namely the lack of any provision for greasing the rockshaft, and the fact that to repair slop in the rockshaft due to wear, it has to be cut out of the hitch and a new one made. The hitch on my 782D is very worn and has a lot of slop from the rockshaft and bushings wearing out. Someday I'll have to cut it apart and make a new rockshaft for it.
To overcome this on the hitch I am building, I'm installing bronze bushings in the rockshaft pivot and a grease fitting on each side to allow them to be lubricated.
Attachment 19304
Attachment 19305
Consequently, the rockshaft can't be welded together, so all three of the arms on it will be attached with 5/16" spirol pins to allow disassembly to replace the bushings as necessary.
Attachment 19306
Attachment 19307
Attachment 19308
I worried for years about welding the bushings into the plate without warping something and making the rockshaft stick, but luckily there were no problems. I have no idea when I'll finish this for good, though; while I have bought most of the other parts, and only have a few small parts to make, I still have to add hydraulic lift before I can finish the hitch, and that's going to be quite a project. I also have no real need to finish this in the near future, so maybe in another 5 years it'll be done:ROTF1:
cub1782 01-07-2012 11:32 PM
Matt where did you get that back plate?
ACecil 01-07-2012 11:36 PM
Nice job, Matt! It will look great on your 582! :beerchug:
ajcombs 01-08-2012 12:43 AM
Thats pretty cool!!
Cubcrazy 01-08-2012 09:46 AM
Looking good Matt:beerchug:
Matt G. 01-08-2012 10:04 AM
It's a repro of the OEM bagger plate that I got from somebody several years ago. Original ones occasionally show up on eBay from time to time, but it turned out someone near me had this one they didn't need. I'll also have to weld nuts into each of the holes, too.
The next one I build after this will be done with readily-available raw materials only...I'm not counting on being able to find another one of these bagger plates.
Methos 01-08-2012 11:51 AM
Great work Matt! I'll still be here waiting for you to finish it!:biggrin2:
cub149 01-08-2012 12:21 PM
Nice work. It never made sense why the rockshaft was welded together inside the bagger plate.
Don't worry, the next five years will fly by and you'll have it done.
cub1782 01-08-2012 12:36 PM
Thanks Matt now I need find one for my diesel. Great work!!!!!
jbollis 01-08-2012 01:01 PM
Looks good, Were did you source those bushings from ?
