-   -   1606 shifter (https://www.onlycubcadets.net/forum/showthread.php?t=15251)
j-man5.0 01-08-2012 03:12 PM
1606 shifter
Anyone know what models shifter would interchange with a 1606?
_DX3_ 01-08-2012 03:38 PM
What is your serial number?
cub1782 01-08-2012 06:00 PM
Mine wasn't changeable with a cast iron rear,but if should be inchangable 1050,1806,1535 and maybe some other I can't think of.
j-man5.0 01-08-2012 10:45 PM
Ill work on getting that serial number tomorrow, its my buddys tractor
j-man5.0 01-09-2012 09:32 AM
Got the serial number its 0320023u
_DX3_ 01-09-2012 09:40 AM
There should be some numbers after the "u". That is what I need.
Should look like this 0320023u737625
j-man5.0 01-09-2012 10:23 AM
0320023u202054 is the whole number, thanks for your help.
_DX3_ 01-09-2012 11:09 AM
2 Attachment(s)
OK not sure about the deal with the numbers but after some looking around the 1606 was made in 1985 and 1986. The graph below shows the serial numbers per year for the 1606.
Using those serial numbers on Cubcadet.com's parts site it looks as tho the shifter parts are used on:
1050
1604, 1606, 580, 582 and 1806
The listed charts will help you.
Serial numbers:
Attachment 19365
Models that share the shifter parts and their serial number rankings:
Attachment 19366
Matt G. 01-09-2012 04:12 PM
1604 and 580 have a Peerless 4-speed, so that shifter won't interchange.
Basically any aluminum rear 3-speed shifter should interchange.
j-man5.0 01-09-2012 09:40 PM
Thanks for the info guys i appreciate it :beerchug:
