Hydro leak
My newly acquired 149 has a leak that appears to come from between the transmission and hydro unit and only leaks when it is running. Does any vendor sell a reseal kit? Are any special tools need to reseal? The factory service manual is a bit vague. Thanks
No special tools. Just requires about 4-6 hrs of your time. Fairly straight forward.
http://i176.photobucket.com/albums/w...ydroGasket.jpg |
Is the gasket illustrated the only one between the hydro/trans? Are seals installed on the upper and lower shaft? Thanks for your help.
The previous image is the ONLY seal that is between the Hydro Unit & Rear End.
:Welcome2:
Your local cub dealer or any of out great site sponsers will have the gasket. |
| All times are GMT -4. The time now is 05:47 AM. |
