-   -   tiller pushes my 682 (https://www.onlycubcadets.net/forum/showthread.php?t=16519)
4SPEED 03-16-2012 04:36 PM
I thought you guys said a hydro will hold back a tiller.
TheIHMan 03-16-2012 04:59 PM
It all depends on the soil, unworked soil will push any cub. Even worked up ground will push a little. The only way to help is to put on wheel weights and fluid in the tires.
Matt G. 03-16-2012 05:06 PM
It will hold it back, but not as good as a gear drive.
If any of the hydro linkage or trunnion is loose, that's not helping anything, either.
4SPEED 03-16-2012 06:29 PM
it was my wife's flower beds. there mostly all mulch
it wasnt skiding the tires . it was pushing like it was a gear drive in neutral
Merk 03-16-2012 08:14 PM
Nothwest Ohio is heavy soil. You will need to make several passes with each one slightly deeper than the last pass. First pass is around an inch or 2 deep.
4SPEED 03-16-2012 10:06 PM
there is 0 dirt / soil in my wifes flower bed. just years and years of mulch and sand.
red56turbo 03-16-2012 11:09 PM
Whenever I till with my 149, if the ground is virgin or harder than bleep, I have to feather the hydro lever some. What I mean is when it starts to push you, pull the lever back some towards neutral. It works for me. I also take a few passes going deeper with each pass.
4SPEED 03-16-2012 11:21 PM
in 2 weeks I'll take it to a bigger garden so I can play with it. her flower bed isnt very big . it was only 10' long. by the time I think I got it slowed down , it was time to lift the tiller.
how do I check the hydro oil? dip stick? it has a Fram filter on it , should I change it to a cub filter? part # anyone?
Jeff in Pa 03-17-2012 10:41 AM
Originally Posted by 4SPEED (Post 121590)
....snip......
On a NF, it's filled to the bottom of the plug in the rear cover. What is your fram filter number? That way someone can cross reference it. I know NAPA has filters that are correct for cub cadets
_DX3_ 03-17-2012 05:07 PM
Located in our technical library
http://www.onlycubcadets.net/forum/showthread.php?t=12
