3 rib front tires
what size should I be looking for, for my 582. the size on it now is 16 6.50 8 I think. all I see on epay is 4.00 x 8 with tubes.
http://www.ebay.com/itm/400x8-4-00x8...53792769338358 will they fit or look odd? the 125 needs a set too. I know they'll fit that. |
There are 2 different styles of 4.00 x 8 rib tires:
http://i152.photobucket.com/albums/s...de/rib0408.jpg Your 582 has the wider rim. Some have installed the narrow rib tire on the wide rim. They didn't look right. One other problem you may have is most if not all narrow rims go on a 3/4 axle. Your 582 should have 1 inch axle. I know a few that modified the wide rim by narrowing the wide rim. |
Doug, there's a tri rib available in the 16x6.50 size.
thanks Dale. what are the ones on the right in the pic?
I guess I'll need to find some front rims to cut down. the ag's on the front dont make the look im going for on the 582. |
a little salty I think
http://haydenenterprizes.com/2-New-1...-P1341878.aspx |
thats a nice looking tire. I got to have them. :bigeyes:
Check with Miller Tire. They have a few different styles. http://www.millertire.com/categories...res/16x6-50-8/ Their location is in Wauseon, Ohio. They go to several shows. |
| All times are GMT -4. The time now is 09:31 PM. |
