-   Briggs & Stratton Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=55)
-   -   Kohler S/G work on a briggs? (https://www.onlycubcadets.net/forum/showthread.php?t=17405)
Tater 04-25-2012 12:20 AM
I bought an old allis chalmers b112 with a 12hp briggs and its missing the starter. I have an extra starter for my 149, just wondering if it will turn the engine over the right way. I read somewhere that some starters turn the opposite direction than whats on cub cadets.
Sam Mac 04-25-2012 08:08 AM
Think I'd post this question in the engine section or PM Matt G
darkminion_17 04-25-2012 10:09 AM
Those turn clockwise.A cub one turns anti clockwise...I got one from a ac for my log splitter.It was from a forum member for $15
Matt G. 04-25-2012 04:54 PM
As far as I know, only Cub Cadets have the CCW starter/generators. Everything else I have seen uses the CW ones, so no, you can't use one from a CC unless it is mounted in the same orientation that it is in a CC.
Tater 04-25-2012 10:55 PM
Its mounted on the right hand side, but is turned around(pulley towards the rear). Thanks for the help!
Matt G. 04-25-2012 11:08 PM
To avoid confusion, I'll word it this way, since 'front' and 'rear' are application-specific and can be ambiguous in this case: If the S/G drives the PTO end of the engine, the Cub S/G will work; if it drives the flywheel end, it won't.
Tater 04-25-2012 11:16 PM
It drives the flywheel end. The briggs sits in the allis the same way a kohler sits in a cub. I have a green(john deere?) s/g layin around, I'll see if it will work.
darkminion_17 04-25-2012 11:18 PM
The motor on a ac is mounted like a cub one but the starter pulley on the motor is on the fly wheel side.The S/G needs to turn clockwise.You should look for the correct one, just my 2ยข.
jcsmith 05-03-2012 08:29 AM
S/G
I thought I read somewhere that the S/G could be changed to CCW or vice-versa
Matt G. 05-03-2012 04:38 PM
Yeah, probably in another current thread...the field coils and brush holders would need to be changed.
