-   -   71 wiring ? (https://www.onlycubcadets.net/forum/showthread.php?t=17700)
travis.robben 05-05-2012 10:03 PM
71 wiring ?
Hey,
I bought a 71 Cub and I was wondering if any one could help me out with a wiring diagram ?
_DX3_ 05-05-2012 10:07 PM
Page 1-26 located in the service manual located in our tractor technical library:
http://ccmanuals.info/pdf/1x2-3%20Service%20Manual.pdf
R Bedell 05-05-2012 10:39 PM
NF wiring diagrams are located on page #4 in the Technical Library Section.
travis.robben 05-05-2012 11:13 PM
thanks on the diagram but got a nother problem when you push in the clutch to put it in gear it grinds and when you get it in gear and you push in the clutch it keeps going whats WRONG?:bash:
Poor 104 Owner 05-06-2012 12:26 AM
sounds as if the clutch is out of adjustment thus it is not releasing to stop the trans from spinning to allow you to put into gear with out grinding and also not stopping when already in gear
R Bedell 05-06-2012 08:48 AM
The above link that DX_3 posted is the Service Manual for the 1x2/3 series. There is a section in there in drive line clutches.
zippy1 05-06-2012 10:20 AM
My 100 was doing that when I got it, Matt told me to lock down the clutch pedal and put a puddy knife between the clutch disc and presure plate, sounds like it's rusted together, check it out.
Hope it helps.
travis.robben 05-06-2012 06:15 PM
well there is a saprise because the disk in between the plates is rubber
Matt G. 05-06-2012 07:27 PM
I find that pretty hard to believe. The disc is made out of very hard, non-metallic friction material. The later ones have a piece of it bonded to either side of a metal disc.
jbrewer 05-06-2012 08:41 PM
Putty knife...it worked for my decrepit O that had rusted together.
