"O"s with lights
Is there a original part for a on/off switch for the lights? If there isn't, how did you do your switch if you have one.
Sorry no more for sale. |
From my understanding, the wiring diagram had them mounted kind of under the battery box on the driver's LHS, but toward the engine.
Cub Cadet 123 |
Thanks for the picture. Where on the console is it supposed to go?
I just drilled my holes a couple of days ago. I had to zoom the pdf to see where I needed to drill the holes. I drilled 3 castings and 2 dash towers and had no problems. On the grills I located the top hole and clamped the light bracket on the grill and used that to line up the bottom hole. That way I knew the hole were in the right place for the brackets.:TwoCents: http://ccmanuals.info/pdf/O%20Light%20Install.pdf |
Thanks guys
Your welcome!:beerchug:
Funny thing my parts manual dated 1963 shows it being on the right.
I just got a set of lights for mine so any info will help me install them. :beerchug:
| All times are GMT -4. The time now is 12:32 PM. |
