cub cadet 127 only 1 speed
I have a Cub Cadet 127 when I move the speed control lever (slowly) to go forward or even in reverse the tractor takes off fast and only goes 1 speed. I was wondering if there is an adjustment underneath the tractor to fix this problem? The hydro oil and filter have been changed recently.
http://www.onlycubcadets.net/forum/s...ead.php?t=4643 |
You may also need to check the trunion.
Here is the repair link: http://cubfaq.com/trunionrepair.html |
You made sure it is the correct filter for the transmission and not using an oil filter?
Yes, the filter is a Fleetguard HF6096. Thank You.
Cub cadet 127 hydro problem
I would check the hydro lever adjustment under the tower area. You pull the battery and then use either a crow foot or a wrench(1 and 1/16 or 1 and 1/8) tighten down until drag is just enough to hold lever . I had to make a wrench work by cutting it in half and grinding on it to fit. My cub was like a speed demon until i did this adjustment. What a difference it makes.:beerchug:
| All times are GMT -4. The time now is 08:47 AM. |
